Belt replacement 2V engines
239desmo
Is it nearly bedtime?
August issue of Classic Bikes has a step by step description with detailed photos of belt replacement procedure.
It makes it look extremenly simple and they use a 5mm allen key to check the tension.
If you are thinking of doing this job yourself on an "older" bike it is well worth buying this issue imo.
For lovers of non hoover belt models there is an article on the 860 rebuild from the beveltech.org website.
