Pict
Spare you all the details, but the SL was finally up for it's inaugural run tonight.
Battery (CB16AL-A2, not YB16AL-A2) has been on the charger/conditioner about a week and went from bulk charge to trickle charge after about 6 hours i.e. normal. Heavy connection to starter with the wee boot that holds all the water is nice and clean.
Started up in the shed nae bother, got it off choke, checked all lights etc everything OK, didn't miss or anything on full beam, switched off, wheeled outside, got gear on and.... click click click click click on the starter button.
Back in the shed, tank up, charger on - after about 10 mins gave it a try not really expecting anything and it fired up, crisp as you like. Switched off, about 12.4v across the battery, started again 12.9v across the battery at a fairly lumpy (engine cold) idle - would have liked to have seen a few more volts there but not enough hands to hold probes on terminals and blip throttle. Bit late /quiet to risk a wee run especially if there is to be a push home involved, so have left the charger on for now.
What do you think? New battery will sort it, or more complicated?? Will I just get an old fashioned YB16AL-A2 with acid sloshing around or is there something available now between that and an Oddysey?
David / Scott - do you have a 'first reserve' for Sunday?
(hopefully just battery needed)
