Balancing act
wheelybin
I'd like to check / adjust the carbs on my 696- yes I know its fuel injected and probably the wrong word but..
I'm used to use vacuum gauges and adjusting the slider height on my old Jap stuff from years gone by, buts how are these modern gizmos done? Laptop and vacuum gauges????:confused:
I've no information on how the job is done but synchronising the throttle bodies is the term your looking for
It is done at the factory and not supposed to meddled with thereafter. But if you feel you really need to it's much the same as balancing carbs using vacuum gauges. The take off point can be seen in the picture in this thread and if you look carefully you can see the adjustment screw in between the two throttle bodies. The air box need to be off for access. and the adjustment should be done to balance the throttle bodies with the throttle partially open, not at idle, say 2 - 3000 rpm.
The idle balance is done using the air bleeds but this affects the CO and should be done in conjunction with the idle mixture trim and using a CO meter. Read up on it here: http://www.bikeboy.org/ducati2vthrottleb.html. It's not quite up to date but you'll get the gist of it.
The synchronization is not to be disturbed you say? That's interesting as both my bikes were out. Re-doing it made quite a difference. When I do the synchro I screw the bypass screws fully home and do the adjustment at about 2-3000rpm as Derek recommends. Then I set the CO2 at idle and then open the bypass screw on the cylinder with the highest vacuum to equalize them. Seems to work well. I set the CO2 at 4% using a Gunsons gass analyzer. When setting the idle synchro you will probably need to increase the idle speed at the adjuster and the tweek it down again after. Apparently the CO2 adjuster lifts or lowers the whole fuel map.
I didn't say that it's necessarily right though :rolleyes:
I think a lot of bike come out of the factory that are incorrectly set up. I've come across several bikes with linear throttle position sensors that have been incorrectly set at the factory. The TPS reset is done from software but if it is mechanically out it will never be right. There is no factory procedure for mechanically setting them, but it can be done.
Have to agree Derek about half the bikes I,ve serviced this year TPS needed reset.
The first Ducati I ever worked on was a 900SS back in 96. I was working as a motorcycle mechanic at the time. The bike came in for it's first service so I got the book out and started doing it by the book. I have to admit being surprised when it called for the ignition timing to be checked but not as surprised as I was to see how far it was out! Unfortunately I trashed the gasket and we didn't have a spare so the guy was a bit @@@@ed off when he couldn't get the bike for the weekend (It was Thursday). He was however VERY pleased with the result though. 'I was disappointed with the bike when I got it but now it goes like it should'. It could be hard work being an MC mechanic but stuff like that made it worth while.
