Hi
Can anyone shine some light on why my back brake is sticking on on my Multidtrada?If I use the brake pedal the back brake stays on unless I repeatedly push down on the pedal again.It doesn't lock the wheel as it is @@@@ anyway but it's a pain in the rear end
I checked the pads and they have about 3 mm on them .The fluid level in the rear cylinder is fine also.I'm guessing it must be the rear master cyclinder or the pistons sticking within the rear caliper.But what do I know!The pedal moves freely as does the piston.
Any help would be appreciated before I start to strip it down.
