An oil leak!
BruceCampbell
:eek: Over the weekend have done 500miles to get the monster run in for first service this thurs at D G....Looking at the bike today there is what appears to be oil on the gearchange side of engine, not much but just enough to notice!! I cant see the source, but this can not be normal!! I have followed running in instructions to the letter any thoughts please:confused:
There has been a long running thread on Ducatisti about Monsters with left crankcase oil leaks. These generally seem to have been from the RPM sensor gasket but there has been at least one incidence of a porous casting.
A new bike shouldn't leak oil! Take it back to the dealer and get it seen to. They should be able to find the source and correct it, but if it still leaks be persistent.
Gutted!
Derek
Thank you for the valuable info..If I had known that there was an ongoing problem I would not have bought the bike:mad:I am really peed off at the thought of a brand new bike being less than I thought it would be! Will be speaking to D G tommorrow to clarify way fwd....Let's hope its an easy fix because if its not they will get the hair dryer untill its fixed!!!
Bruce
Bummer! My 696 had an oil leak after its first service too. Not what you want from a new bike.
Took it to ERS in Dunfermline where it was sorted under warranty. Apparently it was over filled but was leaking from a loose allen screw.
Was quickly fixed and no bother since. Bit of a hike to Dunfermline for me tho,
Hope yours is sorted so easily.
Progress
Ducati Glasgow have been brilliant today...Bike is being picked up from mine through Ducati Assist tommorrow morning and will be returned to me fixed serviced with termis and tail tidy on...feel much happier having calmed down a bit!!:)
You will have no issues with DG. TOP GUYS
