iconic944ss
While the irony at only ordering and getting this repair kit the same week that I had my first puncture in years, wasnt lost on me, yesterday, during the 'Double Chopper' run...
However, just how an oblong, flat of alloy with hardly any sharp surfaces could puncture a perfectly good Pirelli Angel back tyre, is beyond me. The only saving grace was that it was right in the middle of the tyre and close to a petrol station.
Thankfully, I had assistance from Miles and Shaun so the hard part of getting the damn object OUT of the tyre was a good team effort. The kit contains almost everything to get the job done (except a rubber glove that Miles kindly donated, that saved a possibly frozen hand)!
A 'router' (serrated, pointed screwdriver type tool), is used to smooth and open out the wound in the tyre with the tool needing a liberal covering with a liquid rubber glue.
An odd tool like a giant inverted sewing needle with a handle is then used but once once the 'needle' has been threaded with a strip of sealing strip that looks like a badly fried french fry. The loaded needled is pushed into the tyre so that only a half inch or so is left outside, then after giving the tool a quarter then, its retracted, leaving the sealing strip in place.
A blade is provided to cut down the protruding strip to the level of the tyre and then its time to inflate. After buying a mini-inflater and carrying it un-needed all the way to Italy and back I was a little miffed at not having the thing when I needed it but, it all worked out, in the end.
Adapters are provided to fit almost any valve combination and 5 CO2 cylinders of compressed gas which screw into the adapter and (hopefully), inflate the tyre. Worked a treat I must say, I think I should of installed the adapter so that the gas cylinder was pointing DOWN-OVER, into the valve, rather than the other way.
The cylinder does get very cold as the frost on the cylinder and the tyre valve showed but at least its an easy means to show the gas is going in the tyre. I only used two cylinders to get a half decent pressure in the tyre for the 100 yards ride to petrol station for full inflation.
I've not checked the pressure since getting back but the repair held fine for the rest of the 80 or so mile to get back home again. Everything felt fine at up to 70mph but I'm afaid I have little faith in this being no more than a 'get-me-home' repair, which it did, admirably.
Its currently half price from Motohaus, here:
http://www.motohaus.com/acatalog/Airpro-Premium-Tyre-Repair-Inflation-Kit.html
