Air in front brake
dancingdog
HOW???
every time the bike stands for a day or two I lose the front brake & have to bleed it.
& before you answer RJock - I know the answer is ride the bike & not let it stand :D
Assuming you're getting all the air out in the first place it can only get back in through a leak. Either at a caliper seal, the master cylinder seal, one of the banjo bolts or a bleed nipple. I think that if it was leaking at a caliper, banjo or nipple there would be evidence of brake fluid around it. Perhaps not obviously at the master cylinder though, although the fluid would need to go somewhere to make room for the air.
Another thought is that perhaps you aren't getting rid of all of the air and your attempts to bleed it out is pressurising the system so that the air dissolves in the fluid. When standing for a day or 2 it comes back out of solution and the lever goes soft again. Might be a load of havers but just a thought.
took extra time to bleed it tonight with pipes on my nipples & jars full of fluid.
If Im soft in the morning:D I know i must have a problem
Had a similar problem with my rear brake.The only way I could get the air out of the system was to reverse bleed it.
I know you can buy fancy bleed tools.But all you need is on old fashioned trigger type oil can and a piece of clear tube.Fill the can with brake fluid attach the tube to the bleed nipple,slacken nipple and pump the fluid from the caliper to the master cylinder.
If you can get hold of a syringe (or maybe the chemist) and some tubing it makes it an easy way to push the fluid through from the bleed nipple.
Sensible advice - rubber band round the lever to pull the brake fully on. Tap calipers with wooden handle end of a hammer, and also pipes to dissipate some of the air bubbles in the fluid. Leave overnight, the air can migrate up and out of the system into the master cylinder. I never use brakes anyway - they slow you down you know! :D :D :D
We've all heard this one before, but if the lever is pulled in then the bleed hole back to the reservoir is blocked by the piston, so how can the air get out of the system? :scratchhead: Does it really come out of the system or does it just dissolve in the fluid due to being pressurised for a prolonged period to re-emerge at a later date?
I prefer to get a hard lever by bleeding - I don't believe in magic :p :D
Yes but you release the band, the air can then come out to the top. It some cases it can just help. It all takes a bit of time, there is no magic cure agreed. Then bleed the system through again having taken some of the air out of the system. Pressured fluid feed is best but that isn't always available. It leads me to think there may be problems with seals anyway.
Yes, if when you release the band and all the air has accumulated at the highest point it may well exit to the reservoir, but the highest point is often the master cylinder banjo and it might need bleeding from there. I'm agreed that DD has possibly got a seal problem.
