Advice please
ian900ss
SS is off the road at the moment, getting some stuff done. It's getting HI COMP pistons, when I took barrels off they had a noticeable lip. Got the nikasil replated by Langcourt. I am also replacing head bolts, stem seals as well as repainting engine.
My question is, if the barrels had a lip should I examine the bottom end, possibly split cases? Especially if I am putting in new pistons etc, or should I leave it if it isn't broke? Is there anyway to tell if it needs done? Bikes done about 30,000 miles
Any help or advice appreciated
I'd leave it alone Ian. Some of these engines have done over 100,000 miles and are still going strong. Although the top ends seem to wear and they burn a bit of oil the bottom ends seem to last well.
It could be worth checking the oil gallery plug though. With the primary drive removed you should be able to feel any roughness in the main bearings by turning the crank. Although splitting the cases and removing the crank is the only way to properly inspect them. Then when it's out you could remove the conrods and check the state of the main bearings and the crank journals. At this stage you'd probably end up replacing the main bearings and big end shells, simply because having gone that far you might as well do them anyway to be sure.
Thanks Derek, I don't want to take the bottom end apart if I can help it, so as u suggest may leave it alone. Will definitely try to examine plug whilst it's in bits. Was just worried bottom may have been worn going by the bores.
Ian
Ian
I'd definitely check the oil gallery plug. My 900 had about 28000 miles on when I swapped the barrels over. You could just see the plug starting to work its way out at that point.
On splitting the cases it was discovered that the main bearings needed replacing. The big ends were half worn, so they were replaced as the engine was in bits anyway.
I think I have a photo somewhere of the escaping gallery plug if its any help.
Rich
Rich,
That would be great if you could email it or post it here?
What made you split cases was it cause of the plug?
Ian
Ian,
PM your email address I'll find the high resolution one for you.
Yup, it was the plug that caused me to split the cases. I'd swapped the barrel's over for the ST2 944 conversion and knew the gallery plug was a common issue on the 900. We had a good look in there and could see it just starting to work its way out. I figured it would last a bit longer, so ran the bike for another month to see what the barrel conversion was like and took the bike off the road.
I know splitting the cases is a big job, but it did end up with the engine getting sorted out properly. Main bearings and big ends replaced, as was the gearbox due to 6th gear having pitted teeth. I also fitted high compression pistons and had the crank, rods and pistons balanced. It was a good chance to get the cases sandblasted and repainted properly too, so it all looked nice again.
I know the engine is now solid for another 28000 miles, so worth it in the end.
Rich
