sideshow
Hi folks
Wonderin if anyone can help me. I have been having a slight problem while trying to adjust the rebound damping on the (ohlins) rear shock on my 1198s. I am using a ball ended 3mm allen key, but when I turn it, it feels like the key is turning IN the bolt, rather than turning the bolt itself:dunno:. I don't want to try and force the issue, as I don't want to feck the allen bolt on the shock. Anyone done this before? Is there a way to adjust the shock so that the bolt lines up with the hole in the swing arm better
