Adjustable fuel pressure regulator
Don't know about these ones but issue I had when looking for something for my project was a lot of them could not be turned down far enough for a bike and pressure was just too much.
Curious to hear your verdict.
The ones we use are rated at 3bar and these are supposed to be adjustable between 3 and 5 bar. The ad gives the seal dimensions which I've just checked against the ones in the 748 and they match so this regulator should fit. My only worry is the length. It looks like it will be too long for the 900SSie but may just fit the 748.
Why do you need an adjustable regulator? Have you reached the limit of adjustment on your map-tweaking device? Just curious, as I am fitting fuel injection to my (non-ducati) trike project and like to learn.
The standard 3bar jobby costs about 80 quid, this costs me 25 inc. post. Somebody has obviously be at the regulators on both my 900SSie motor and my 748, the back of the regulator has been pressed in which increases the fuel pressure to the injectors. This increases the fueling for a given opening time. I need to reduce the pressure again as both are indicating a rich mixture.
Plus it also gives me something else to play with :).
