Adhesive for carbon fibre?
Ardenstorm
I have been trying to attach mounts for the rear tailight unit on my 916. Tried a couple of different adhesives & mastic with poor results. Any idea as to what will do the job?
Thanks in advance.:comp2:
the best bond with come from using an epoxy resin and more carbon fibre sheet shaped around whatever you are trying to attach but you may need to key into the existing carbon first. its not easy to get a strong joint :(
