A wee tip for 2V valve adjustment
Derek
Those of you who have fought with the closer springs to remove and replace the closing shims might like this idea I came up with a couple of years back. When I was swapping the 907 heads I took a few pictures.
A 10mm Allen key placed under the rear of the closing rocker holds it open and makes removing and re-fitting the shim and half rings much, much easier. Removing the risk of half rings disappearing into the aether or gouging a hole in the valve stem seal when the screw driver you are holding the rocker down with slips off.
It's a good tip Derek.
I did something similar with a BFO screwdriver earlier this year when I was getting rid of the burr that built up after the clearances on the Monster got too big.
Great minds! :D
I might have used a screwdriver too, if I had one that big, but the 10mm Allen key fits perfectly. Whatever you use it makes the job far easier. :)
