999s Recommended Oil
  • Thread starter Thread starter alane
  • Start date Start date
A
alane
Just visiting
Nope, not another Oil question thread.
As I was clearing a load of old stuff out, just thought I'd post the results from a query I sent to Rock Oil regarding best oil selection for the bike. Not prompting for discussion, just for info - and I don't have any connection to RO.
The return answer was:
I’m going to suggest another oil which you haven’t mentioned and that is Synthesis 4 Racing (a fully synthetic 15W50). Nothing wrong with either of the oils you have stated, but there are reasons to choose this particular one over both TRM and Guardian. As you have mentioned Guardian is a semi-synth and a very good one but seeing has how your running a very expensive bike I would suggest using a fully syn product giving you that bit better protection and performance. TRM is a full synthetic but is a good bit thicker than the Syn 4 racing and is maybe best used on older V-Twins where the thicker make up would be of more benefit on engines where the tolerances aren’t quite as good as on the more modern kit like the testastretta (have I spelt that right? It is Monday morning) engines. We find the TRM sells to owners of bikes over ten years old or in endurance racing. We also supplied Syn 4 Racing to Renegade Ducati a few years ago who were running factory 998’s. We have supplied this oil to other teams running the 999’s and all have been pleased with the oil.
Any more questions then please ask or I can get the technical manager to call you if you need someone with more nous than myself
The technical spec:
SYNTHESIS 4 RACING
MOTORCYCLE ENGINE OIL
Synthesis 4-Racing - The most advanced fully synthetic four stroke engine lubricant available.
Synthesis 4-Racing is a complex blend of pure synthetic base stocks, coupled with state of the art additive technology, and is formulated to pass every test and high performance test specification known, providing an impressive list of approvals.
During extensive development testing, Synthesis 4-Racing proved to be an oil for extremes. Its wide viscosity range (15w50) gives top protection from cold start conditions to the severe heat of competition whilst the complex range of additives significantly reduces wear and keeps your engine internally clean.
FEATURES
 Outstanding thermal and shear stability.
 Exceptionally low volatility.
 Excellent control of engine deposits and blow-by contamination.
 Superb wear protection.
 Significantly reduces friction, releasing full engine power.
 Passes crucial clutch friction test required to meet the JASO MA specification, allowing safe, predictable use in wet clutch applications.
Synthesis 4-Racing meets or exceeds the following specifications:
API SL
ACEA A3
JASO MA
TYPICAL PHYSICAL CHARACTERISTICS
Viscosity Grade SAE 15w50
Density @ 15C 0.854
Viscosity @ 40C 130.0 cSt
Viscosity @ 100C 18.9 cSt
Viscosity Index 164
Appearance Clear Amber Liquid
