A
alane
Just visiting
Whilst all fairings are off (just to change the low beam headlamp bulb!) thought I'd drop the oil and give it the once over with new filters et cetera but stopped at first hurdle:
Oil drain - on the 999 there's the smaller plug which looks same as the 749 oil drain, but there's also the larger drop down stickey out plug thing held on with 4 bolts.
Which one is the one for draining the oil - or are they both the same and Ducati just didn't bother changing the castings?
Thanks
Thanks
