999s Coolant leak solved
  • Thread starter Thread starter alane
  • Start date Start date
A
alane
Just visiting
Couple of weeks ago when I started the bike up I saw a pool of liquid develop underneath after a minute or so.
Having already had a standard 04 999 which had the dreaded oil cooler split I was immediately pee'd off in case the same problem was affecting the latest models.
Bad news was it was leaking.
Good news was it wasn't oil - it was coolant.
So after rearranging homework I got today free to check it out.
Stripped the fairings off and started it up.
Coolant was dripping rapidly from the bottom left radiator hose connection.
Nipped it up with 7mm ring spanner and all is well with the world.
Top up the coolant (40/60 shell/water) cos it lost about half a pint.
Moral of the story - from two experiences with leaking bikes I now always let the bike run for a minute or so before setting off for the first time that day and check for leaks.
had exactly the same problem with my 999 when brand new,also had various brackets/bolts loose,so much for pdi's
still a brilliant bike tho' :thumbs:
had a similar experience when a stone got jammed between my fairing and the oil filter and eventually wore a little hole in the filter......letting the bike sit and warm up before driving off allowed me to notice the small drops that were falling off. couldnt believe it wheni saw what had happened :shocked:
