The dog's bollocks!!!I did wonder I have these for 998 monster takes out the squeaky bum
I bought one - load of shite and it didn't fit.They only lock up the exhaust and inlet sprockets.I have seen the plastic ones designed to lock on the inside of the gears
I bought before brexit kicked in , it was about 220 postedThe dog's bollocks!!!
I was looking for those everywhere online but none around. . They immediately line up and secure the cams correctly and the sprockets can be tweaked independently to accommodate the belt's teeth.
I will check Ducati Aprilia Kamna to see if they have any more in stock!
When the horizontal cylinder is timed at TDC and the belts fitted, the vertical inlet cam is trying to close under pressure of the closing spring. When all the timing tools are out, this pressure tightens the belt. It can show up as an increase in the Hz reading using the tensioner tool by up to 30 or 40 Hz. That’s why, once the horizontal tension is set, the motor should be rotated 270 degrees to put the rear at TDC.In Ducatitech's video, the guy instructs us to set the vertical cylinder at tdc before tensioning, testing and re-tensioning the belt. I can't think of a logical reaon for this as I would imagine that the tension in the belt, taken from the position shown in the workshop manual, is the same at any point in the combustion cycle.
Is there a reason for this?
I was but stupidly let it lapse a few months ago@Richie53 are you by any chance a member of DOCGB? They have all these tools and let members use them.
