999 Valve Clearances
Ideally, the cams should be locked via whatever means you have to hand for belt changing, however it is common practise to time engine up and mark the belts and cam pulleys, transfer marks onto new belts without the aid of locking the cams, job jobbed.
For tensioning, horizontal first, TDC on fire stroke, then turn engine 270 degrees for vertical cylinder to be TDC on fire stroke and tension.
I did wonder I have these for 998 monster takes out the squeaky bum
The dog's bollocks!!!
I was looking for those everywhere online but none around. . They immediately line up and secure the cams correctly and the sprockets can be tweaked independently to accommodate the belt's teeth.
I will check Ducati Aprilia Kamna to see if they have any more in stock!
I bought before brexit kicked in , it was about 220 posted
well made and works
In Ducatitech's video, the guy instructs us to set the vertical cylinder at tdc before tensioning, testing and re-tensioning the belt. I can't think of a logical reaon for this as I would imagine that the tension in the belt, taken from the position shown in the workshop manual, is the same at any point in the combustion cycle.
Is there a reason for this?
When the horizontal cylinder is timed at TDC and the belts fitted, the vertical inlet cam is trying to close under pressure of the closing spring. When all the timing tools are out, this pressure tightens the belt. It can show up as an increase in the Hz reading using the tensioner tool by up to 30 or 40 Hz. That’s why, once the horizontal tension is set, the motor should be rotated 270 degrees to put the rear at TDC.
Applies to all motors Inc 2v
