stevewrightscotland
Hi,
Got back from the US on sunday and hopped on the 999 eager for a ride, pressed the starter button and nothing happened
. Pressed the button again and again and eventually it started ... phew. Several hours and many miles later I stop for gas, fill up, pay .... press the button ... fxck ... same thing again. Several presses later it fires up and I ride home.
Next day same again ... It won't start 1st time or 13th time but on the 14th or 24th time it starts and runs sweetly as always.
SO I have a problem to fix. Now the battery is new so its not that. I need to diagnose so over a bottle of red I research the internet starting with DUC Up North and I read about various relay problems and shorted wires etc on 999's and other Dukes.
This is all rather scary so Monday DG is closed but tuesday I phone the weegie guru's, I'm lucky as the head guru Martin answers the phone and over the next 30 mins or so he asks questions and dispenses advice and his conclusion is its either a fuel pump relay or its the kill switch corroded.
I'm not convinced but later that afternoon after a lengthy and inconvenient work-break (don't people realise that a bike problem needs immediate attention???) I'm back in the shed and the 999 fairings are off and I'm ready for some serious repair action.
I start with the kill-switch, 2 screws underneath are easy to remove and once the switch assembly is open all of Martins wisdom is truly revealed ... the contacts and every part inside the switch is covered in orange rust!!! Damn thing since 03 has gone rusty hence no current flows through the start switch.
Much squirting of WD40 and lint-free cloth polishing follows and in 15 minutes I've restored the switch to new shiny condition and feeling very proud I conduct numerous starting tests with 100% success
So many thanks to Martin for his expertise and time, god praise WD40 and I'm now opening another bottle of red to celebrate having my lovely 999 ready for a Moto-GP weekend
Thanks Martin.
Steve
Thanks Martin.
Steve
