999 start problem relay ??
muxey
2003 999 not started for a few months battery on optimate hit the button i
just get a clck pump seems to run but no attempt to kick starter in ?
any sugestions,
I had that happen to my 748. Traced it back to a wee wire, think it was on the back of the starter solenoid, which had wiggled loose. Shoved it back in and away it went.
As I remember the starter relay is on the side of the battery box in the bottom of the left fairing. They are well known for getting wet and rusting up on the spade connectors. Locate the relay ( black plastic cube about 35 mm by 35 mm) clean and Vaseline each connector and wire if there in reasonable condition and try to fire it up. The relays aren't expensive and the boys at Ducati Glasgow were extremely helpful at sending me a new one and explaining the fault.
Best of luck with it.
thanks guys, looks like the battery, voltage is 12.5 but drops to 11.4 with ign on the battery is old so I guess its time it went.
new one on its way !
