Happy New Year folks. I recently bought a 2003 999 Bip. ’05 registered but only 4,000 mls. There is a spacer in the rear wheel, outer edge of hub, disc rotor side. My factory manual shows it being “stepped” (with a shoulder on the outer edge); however, my manual is for an “S” model, not Bip. My spacer is plain, not stepped, 30mm bore, 40mm I/D, 9mm thick. It is badly scored, apparently from the seal running around it. Can anyone confirm if it SHOULD be plain? Thanks very much.
