Exclamation EFI Error 34.0 Signal Panel Sensor explained
Guys,
I have also experienced this error on my 2003 999s. It pops up after having ridden the bike hard, then switching it off for a few minutes, when starting it again. If leaving the bike for more than 30 minutes, it will subsequently go away. Seems that it is the old tale of "Yes Sir, they all do that..".
Anyway, here is the explanation of what it is, as promised:
The error code is poorly translated in the workshop manual. In fact, this can be said in general about the manual. Reading the Italian text helps...
"Signal Panel" is a translation of "Quadro Signali", which actually means "the panel which shows signals", or dashboard, for everyone else.
There is only one sensor embedded in the dash - the Barometric Pressure Sensor, which is used by the ECU to calculate the correct amount of injected fuel. Imagine riding up the alps. The BPS would signal lower pressure to the ECU, which would then compensate by increasing the amount of fuel. However, the BPS is not the only sensor or parameter used in the calculations.
The complete error code reads: "34.0 Panel Sensor Error - (sensor) Disconnected". Now, how on earth this sensor can become disconnected since it is a tiny component which sits on the circuit-board inside the dash is beyond me, but there you go.
What I did was to remove and open the dash and "wash" the board with quick-drying circuit cleaner. Haven't had the problem since. NOTE: I take NO repsonsibility if you destroy your dash (Expensive ! have to buy a factory new one, since it becomes "paired" with the ECU on first use) if you decide to do the same as I did.
Also, if you have the VDTS tool and software, it will tell you this in clear.
br,
IL
