Yep the basket and clutch plate "teeth" wear and you'll probably start to feel it harder to disengage the clutch also. Steve (B&P) is referring to the pushrod bearing in the pressure plate I think, these can seize and you'll hear a whining noise also.
Hi
When i first had my 999r new i thought great no real clutch noise/rattle to talk about but now after 1500 miles yep its rattling do not know if i will ever get used to it but at least the exhaust helps drown it out
micromike
Hi
micromike
