999 clutch hub
yaddd
Hi all,
stripped clutch for clean and inspection and felt some up and down movement on clutch hub?should this be so or is their a bearing behind hub that is showing signs of wear?I am going to order new clutch soon but am now thinking i maybe need more,
any help appreciated!
The only bearing behind there is the gearbox input shaft bearing and I would hope that isn't worn as it's an engine strip to change it. There is however a set of cush drive rubbers in the drum and if these are worn they might allow a bit of movement although I'd have thought it would be rotational rather than up and down on lateral.
Hi derek
bikes only covered 15000 miles and clutch works good.I only took clutch out for inspection as its starting to notch basket and get slightly noisier .I am going to order new basket and plates but was wondering if hub could be worn as I could feel ever,ever, so slight movement on up and down.i have read that theres cush drives behind this so could be them.Do these usually wear out at this milage?I will need to buy tool to get hub, basket off for closer inspection.Its just that i am now thinking of slipper clutch as if i have read things right would replace all parts that could be worn?
Thanks for your reply's much appreciated!
Mine has 36,700 miles on it now and I'm not aware of any problem with the cush drive. However any unusual movement should be investigated.
My clutch is noisy a feck ( I quite like it that way)
Harry in DG said not to worry about the noise till it starts to slip and play silly buggers. Im thinking you should save your cash yaddd and fit all the original plates back in?
Ye for sure I'll be running the way it is till it starts slipping,but I always need to think ahead budget wise,belts due soon too!:violin:
