A
alane
Just visiting
The low beam lamp (on all the time) uses the same type lamp as the high beam lamp.
Hence, if your low beam goes and you are not able to get a replacement lamp straight away, you can always swap the high beam for the low beam, leaving you with the easier to change high beam when you get the new lamp.
(HB3 60W)
(HB3 60W)
