998 Oil leak
TTesta
I've recently become the proud owner of an 2002 998, which I left at home during a jaunt to the NW200. Clearly, annoyed at me for leaving her in the garage, she welcomed me home with a little puddle of oil. On inspection, the oil seems to be dripping off the locator pin on the bottom of the oil cooler, but I can't locate the leak.
If I sound like I have limited knowledge of m/c mechanics, it's because I have limited knowledge...
Ideas, guidance and a little technical know-how would be very much appreciated!
:confused:
If you mean the little metal post in the centre this just locates the cooler in the V panel, I had a similar problem with mine last year and after convincing myself I must have "popped" the cooler and endless searching for a 2nd hand one (IIRC a new one is about 180 +VAT) it turned out to be nothing more than a loose inlet coupling.
