998 Air Box removal - help needed
998gsb
Can anyone help - I am in the process of fitting some BMC filters to my 998s FE 04........
To do this, you have to fit two small mounting guides inside the airbox at the entrance to the inlet ducts. This involves drilling 3 small holes on either side to fix the slides in place, and to do this you have to take the airbox off the bike.
I am having problems removing the air box.....I have disconnected the fuel line to the injectors and the 6 bolts which fix the box to the chassis. The injectors however are mounted directly over the venturis on plastic tripods, with a circular disc around the base, which appear to have 6 quick release tabs on the underside - I assume that removing these then allows you to remove the rubber grommets around the venturis and then just slide the air box off....
My problem is that I cant see how to remove the tripods - they just dont seem to want to move, and I dont want to apply any force as they are only plastic.....
Is my approach right, or am I missing something......any one who has undertaken this exercise, or just knows(!) - please could I have the benefit of your wisdom!!
Thanks everyone..
Gavin
Thanks DesmoMick - actually sussed it eventually!! - Had a look at this site though and there looks to be some great info on it - so thank you anyway! - am sure it will come in handy!
