996 expansion tank
jonb1
hi all, last night expansion tank split on the 996, been in touch with ducati leeds, none in stock, have to order will take approx a week, anyway tonight going to have a go at fixing, looking at drilling a small hole at end of cracks then scooping a little of the split out with a hot soldering iron then filling with epoxy resin.
anyone had any success? i will have to get a tank anyway
I think someone else had a problem with 2 tanks splitting on them on here.
Something rings a bell in my head with 996, tanks and splitting anyway.......
Fraid thats all i can remember but i think they found a solution to the problem.
Maybe a wee search will throw something up
you can get a plastic weld mix from M and P I think, drill the ends of crack and cross hatch it with a soldering iron to give plastic weld something to bond too. I've done this on faiing repairs and it can work, you could always use a fine wire wesh over split and soldering iron/ epoxy that down if you can't get the plastic weld.
Very common failure on 996's. might be worth a ring round, someone like JHP might have one on stock and get to you next day?
I's found that Unibond Plastic Glue works really well on nearly all plastics apart from PVC and polythene. It is a clear epoxy that sets in 15 minutes and is very good for fairing repairs. Another possible is 'Aquasure' wader cement. It is a very tough urethane RTV like Tyger seal, it remains flexible and sticks to practically anything.
The header tanks splitting rings a bell with me too. It is something to do with it getting pressure applied to it by the tank or something. I'll see if I can find out what it was.
Here's the info on the coolant tanks splitting, taken from another forum. One from Shazaam the other from Fariborz Rostami, both on a similar take.
From Shazaam-
The main reason that a Ducati superbike coolant tank cracks is that the tank expands as it get hot but there’s not enough clearance around it to allow free expansion in all directions. In particular, there is a rubber grommet that holds the tank in place and presses it tightly against the frame. Because the grommet is somewhat oversized, it causes the hot plastic tank to be compressed by the frame and receive vibration transmitted through the frame. When you install the replacement tank, trim the rubber grommet to avoid a repeat of this failure condition.
From Fariborz-
The reservoir on 748/9*6 is in a very tight spot. By itself it cannot move from the cage that is in. Typically the bike runs at around 180 F when the bike is moving. At stop and go the temperature can go as high as 215 F. This is particularly true for the 748 that does not have an oil cooler. When the temperature gets hot enough the plastic wants to expand and does not have a place to go. This causes extra stress on the weak points (typically the seams). Repeated temperature cycling of the coolant also causes fatigue in the plastic and further weakens it.
It is best to make sure that the reservoir is not mounted rigidly with any mounting bolts/fasteners. This will allow the the reservoir to expand and shrink freely as the temperature goes up and down. My reservoir had a leak at one of the seams. I used some fiberglass and epoxy and sealed the crack. After I fixed the crack, I simply put the reservoir back but did not use any fastener to hold it in place. The two rubber pieces wrapped around frame prevent the reservoir from rattling. I have not had a leak after the fix and that was two years ago.
And another confirming Shazaam's fix
While you've got the ignition barrel out, do this:.... in the top of the header tank, there is a small black rubber bung. Its just a cushion for gap between the bottom of the ignition key barrel and the header tank. It doesn't actually seal the tank. Pull it out and with a sharp knife, cut about 3-4 mm off the bottom and then refit it. Slice your offcut in to two, and use as a rubber washer to sit beneath the ignition key plate (two bolts). This just lifts the barrel off the bung ever so slightly and reduces the pressure on the top of the tank.
The tank cracks cos of it expanding & pressing against the bottom of the ignition barrel. This is a mod recommended by shazaam, and has worked for a mate of mine who has had 3 tanks go before finding out about this.
Unfortunately, I now need to do it too...........
