996 Death rattle......
stickyjamfinger
For anyone that was on the ill fated smoggie run out last weekend that heard my engine sounding like a steam hammer here's the cause....
Horizontal cyl Iridium plug shed its bloody outer electrode, it danced around on top of piston before being thankfully spat out of exhaust port, no valve damage that I can detect without pulling head.
Lucky also that it didnt get embedded in piston crown and squash ring lands jamming rings(had this happen many times on big diesels that Ive overhauled/repaired)
I did nearly 150 miles with the plug in this state after this happened with no noticeable loss of power but a noticeable stutter at low revs much like it was before Pc3 was fitted...:eek:
p.s. I've got a nice donor ST4 in the garden, low miles, light front end damage only........................................
Had the electrode been bent to alter the gap? Iridium plugs are pre-gapped, larger then normal, and shouldn't be adjusted.
Hi Derek, thanks for reply.
No I just bang em straight in, had a couple of sets throught it already, I always handle them carefully and never alter the gaps.
Most annoyed with my self as proir to the ride I did an oil change and balanced the throttle bodies bt as the plugs had been in for about 1500miles I left them, was going to change them though as I had plenty of them.... cock:o
I meant to say in first post has anyone had or heard of this happening?, how often do you change your plugs?
Daz.
yeap there was no loss of power on the way home...... as you rode off into the distance.....on the back :D wheel
