when the bike is turning over using my multimeter it shows at 13.8 volts, when throttle blipped it does not get any higher, when lights are on low beam it comes down to 13volts, i dont think its charging properley, what do you think?
Not sure on the spec for the 996, but what you say is what I would expect more or less.
The charge is crowbarred at 13.8v and no more, but when brake lights or low beam on then voltage drops slightly.
I'd put lights on then raise engine speed to say 2.5 thou and see if voltage rises.
But then again, the charge is the current going into battery - need to use ammeter range on multimeter and have it in series with positive terminal. Set it to highest amperage to begin with and then switch lower for more accurate reading.
The charge circuit should maintain at least 13.6V. With lights off I would expect to see 13.6v to 14.6V. With the lights on perhaps a little less.
I'd say your voltage regulator is on the way out.
