'97 900ss Oil Temp
Mr Burns
Took the 900ss to Knockhill last thurs for the novice track night. It was a pretty warm evening and the indicated oil temp while on track rose to a steady 150degC. The question is if I'm going to continue using the 900ss as a track bike what do I need to do?
Replace the oil cooler for up rated item use higher spec oil, fit a cooling fan, fabricate some form of airducting, or heaven forbid use the 848:confused:
Check the oil is pumping through the cooler,maybe the cooler is a bit gunked up,a cooler from a fuel injected SS fits,slight alteration to the bracket . I dont think its capacity is any more than the carby model oil cooler but you have more chance of getting a unit in good condition from the newer bikes.
I'm sure there are uprated coolers on the market to,I think people have also added a second cooler,check the Supersport section of Ducatisti.
Add an additional oil cooler mounted per M900.
Am looking at Mocal, Serck, Earls for 'project'. You will need a mounting method to clear rev counter cable. (M900 valve cover)
I don't think a different oil will make any difference.
Fans.. nah. Maybe if it was overheating because you were sitting stationary for long periods otherwise a lot of effort for minimal (if any) gain.
Doesn't it already have the later (ducted) fairings?
Not sure if 1/2 fairings would make a difference. Maybe? :confused:
Check the oil is pumping through the cooler,maybe the cooler is a bit gunked up.
Doh rookie error on my part :mad: The bike has been standing for 3 yrs. I think I'll remove the cooler give it a good flush in the solvent bath at work, then another new filter and this time some decent oil and see where it goes from there. Really want to use the bike on track it's about the right weight and power for me to have fun without feeling intimidated or worrying about dropping it.
Cheers guys any further info gratefully accepted
Set up right and with decent semi synth the standard cooler should be fine. Always remember track work makes your oil work a hell of a lot harder, oil spends no more than 2 hours of running in my SS engine before it's replaced with new. Filter is replaced every second oil change.
Road maintenance schedules go out the window once you get a track habit, respect your bike - it's the tool that makes the magic happen. ;)
