'95 900ss change tank cap lock barrel
Beefy
Hello everyone,
Just come back to a Ducati after a few years on other Italian twins (I am keeping the RSV Mille...).
Has anyone changed the lock barrel on a 1995ish 900ss? Any advice welcome. Thanks.
Hi There,
I've done most tank stuff but never done a barrel change, I do have a keyless cap waiting to go on next time anything goes wrong and the cap needs removing! Could be an option for you.
Cap out can be fun (not), new O-ring seal, good grease and 3 to 5 hands seem to be needed ;-)
Good Luck
The one on the bike is quite scratched and I'm thinking about a new one with two keys from Stein-Dinse, but I'm not sure I can be bothered having a different key for tank and ignition. Keyless may be the way to go if all else fails.
Three bolts hold the cap to the tank, then turn it over and remove the lock. There are springs and other flying parts under there, so go slowly. Worst bit is the tiny ball and spring that hold the flap over the lock up while you put the key in, it isn't vital but if you lose it the flap wants to close all the time. I have swapped several scuffed caps and kept the original locks.
Mike
