94 900 ss engine stand
es2_500
Hi all,
This is probably the wrong section for this, but anyway, thought i'd have a go at making some engine stands for working on the motor when its out of the frame. Me and my son came up with these proto-types, they're like the ones on the Stein Dinse web site.
And this is where they fit up to the bolt holes in the crankcases, they'll probably fit 2 valve monsters too (as your sat on the bike, the holes on the left have 85mm centres, the ones on the right side 50mm).
There are going to be a couple of changes, the slotted bolt hole will go and there will be a plain hole drilled. The hole top right on the first image will have more 'meat' around it.
I can't take credit for making them, that goes to my son and he reckons he could soon make some more if anyone wants a set (he's saved the template for the laser cutter in his computer). The only difference will be the changes to the holes and powder coat might not always be red.
He can't make anymore until the new year but what i'm trying to do is see if theres much interest in them on here. He can make them for 35 quid the pair, the Stein Dinse ones work out at about 100 quid with vat and postage added. If anyone is interested drop us a line on here.
bry
The should also fit any of the 4V Desmoquattro engines, I'm not sure about the Testastreta engines, but probably.
Ok, will do, just have to make sure the alterations are ok. I'll pm you when they're done in the new year
Thats to Wassy and Iconic, (i'll get used to this thing one day), we'll sort out how to get them to you then - i'll keep you updated.
Thanks for the reply.
One comment is that from the photo, it looks as though the stand isnt designed to reach floor level when bolted to the engine.
All the info I've read on strip downs suggest its usually easier to remove running gear and lift the frame away from the engine??? I'm sure others will know better.
I imagine its not too much of an issue to pack the space out.
Oh, yes - any colour for the stands is fine as long as its NOT yellow ;)
Regards - Frank
Hi Frank,
The motors still in the frame (it won't be by this aft) the photo was just to show how they fitted to the motor, the stands are for when the motors out, so you can work on it without it rolloing about everywhere. It would be nice if you could bolt them up while its still in the frame but then its to tall and stability starts to suffer. Me Ducs on an Abba stand so i'm going to see if its possible to drop it of the Abba onto the engine stands and then take the frame off - i'll keep you posted.
Regards - Frank
Hi again, Frank. the motors out and it was quite easy to do. All i did was bolt the engine stand on, drop the back wheel out and free the shocker. Did a dry run at dropping the bike off the Abba stand then put 4 house brick sized blocks of wood where the engine stand was going to sit.
then just swung her back and sat the engine stand onto the blocks (you need 'em so you can get clearance to remove the abba stand too), undid the frame mounts and lifted it away. Took the blocks out from under the engine stand and was left with this.
Can't see why you shouldn't be able to do the same thing with a standard paddock stand as well.
Hope this clarifys things a bit
Bry
Ps - I'll make sure its not yellow, ya can get things done faster with the red ones.
I see you are in North Yorks. We have just bought a place in Richmond so shouldn't be too far away ;)
Hello Wassy, yeah, we'll have to arrange to meet up somewhere if thats ok with you (or can send them in the post), can sort it out when they're ready and then get them to you
Bry
Hi Rockjock / Sam - i'd love something like that but i ain't got a workshop or garage and space is at a premium. Have a bike store but thats got the trailbike in and i don't think it would go down too well if I moved more bikey stuff into the house, just scraped by getting the 900 in. Would appreciate it if you could send us the dimensions tho, i can make one up if i ever do get somewhere with enough room to work on the bikes and theres no washing machine in the way.
Bry
Hi all, back again.
Wassey, Iconic - I'll have your stands tomorrow afternoon - would you like me to mail 'em through - or I could meet you bout 1/2 way, sorta Ripon or west bound layby on A66 at Scotch corner? this weekend.
Bry
It's never too late Monster- i'll se the lad on Friday, if you can Pm your address and what have you then i'll get some sent up to you
Bry
Great news!
I'm nightshift sadly, Sat & Sun.
Guessing they are fairly hefty items - any idea of postage price please?
Saturday morn, might be possible.
Many Thanks - Frank
Hello Bry,
Drop me a pm with your number and I'll give you a call re pick up.
Thanks, Steve.
Bry, I'm off nights tomorrow, so would be able to meet at Scotch Corner but VERY early, as in 8am, which I'm guessing might be too early?
Cheers - Frank
Wassy, Iconic, Monster - sent you a pm but don't know if you got it, so could you Pm us or come back hroughthis and we'll get summat sorted.
Bry
I got my stands today and I can thoroughly recommend then :thumbs:
The quality of the workmanship and the finish is excellent - it's almost a shame to use 'em.
And if you need them posted they are very thoughtfully packaged.
Many thanks Bry.
Picked mine up from the post office today.
Excellent stand.
Bry I've pm'd you.
Cheers.
