All sensors can be tested, its just a matter of knowing what they're doing. most temp sensors are changing their resistance relative to the increase in temperature. So, armed with a meter that has a thermocouple to get a set watertemp (cheap in Maplins, and invaluble for a Duke) Put the working end of the sensor in a jug of water at, say, 20deg, and test the resistance, then 40, 60, 80 etc. Once test figures for the sensor have been found (im looking), poss by funning up a main dealer to get test info, you can be certain as to wether the sensor is faulty, or yer problem lies elsewhere. As a matter of course, these sensors arnt to bad reliabilitywise.
