916 still not fixed! part 2
dan13
My 916 (1998) fuelling issue is still proving to be a mystery, after a day with Duncan at DARL and several calls to Moto Rapido still no joy. With a view to it being an electrical fault I have just carried out an unregulated output test on my charging system and have obtained the following readings;
20v @ 1500rpm
40v @ 3000rpm
75v @ 6000rpm
Haynes specs are 35v, 70v and 140v respectively
The resistance is 0.9 ohms Spec is 0.2-0.4 ohms
Before I have to start removing the crankcase to check the alternator, would the low voltage readings or the high resistance reading affect the ecu/injectors or anything to do with low rpm fuelling which is proving impossible to fix.
The battery is charging fine (reg.output 13.8v)
If you are new to this thread I have ruled out or replaced;
Timing
Belt tension/position
Timing sensor
Coolant sensor
Tps
Injectors
Air filters
ECU
Throttle bodies
Fuel pipes
Fuel filter
Fuel pressure reg.
To check the alternator voltages you need to check the voltages as AC ~ not as DC =. The voltages are approx. half what you would would expect to see, which I believe may be due to this. As for the resistance, make sure the bike is 'off'! Although the resistance value you're seeing, isn't too overly concerning. As Derek has stated though, the DC voltage at the ouput of the regulator shows that there is an adequate supply in to it.
