916 fuel tank O ring size
Positive I have one (748 - the same?), I will go and have a look a wee bit later. If I find it, do you want the size or do you want me to stick it in the post ;)
88650011a - seal ring
It's a bu99er to measure the diameter as it is so soft it won't sit 'round', but best guess is 118mm. Cross section is 3.5mm.
Anyway, I have 2 here, pm if you want one.
