thomp1983
hi guys, today i've stripped my fuel pump out to fit a new filter and submersible hoses, on the base plate there are 2 take offs that join outside the tank and connect to the cap inside it, these are quite corroded so i've set about cleaning them up my first question is,
where the pick is inserted in the first picture is this hole supposed to be open all the way through to the other side seen in the second picture, it's currently obstructed but i can't see if it's from corrosion or something that should be in there to block the hole?
secondly as you can see in the first picture there is nothing connected to the take off on the fuel pressure regulator is this normal?
thanks
chris
thanks
chris
