900SS vs 900SSie differences?
Serious Black
When I got a secondhand ie motor it came with a compete swinging arm and shock. Now I read somewhere that the ie shock should be longer than the carbed bike shock and they sank the forks in the yolks to quicken the steering. My 'new' shock is the same size as my original. Can somebody tell me if there were any geometry differences between the carb and ie bikes?
When I purchased my 800ss ie new (2006) it came with a steel swing arm so I swapped it for a second hand alloy one off a carbed 900ss the dimensions were the same, bike handled just the same.
from memory original 900ss carbie shocks have the small flat screwdriver damping adjusters, whereas the later 900SSie shocks had a nurled knob on the shock reservior. what adjuster types do your shocks have.
Ps the SSIe shock is supposed to be longer, I've got one on a shelf in the garage somewhere to fit to the SL some day.
The headstock angle for the carbed bike is 25 degrees and for the ie is 24 degrees. I'd always believed that this was achieved by the use of a longer rear shock (10-13mm?) but you say the shock is the same length. Assuming the forks are the same length then the head angle would certainly reduce by dropping the yokes to fit the clip-ons above them as on the ie models.
Different swingarms
Were there not different (alloy, steel, new alloy) swingarms or am I thinking of 800 / 1000?
PS the frames are different between carbi and SSIe so its more than just shock length. The ergos give a significantly longer stretch to the bars on the SSIE than the carbi. Had both and the carbi is a comfortable armchair compared to the rack that the SSIE is.
The carbed 750SS had a steel swinging arm but the 900SS had an alloy one. The 900SSie from 1998 to 2000 had the same alloy swinging arm and changed to a different alloy one in 2001. I don't know what the 800SS was fitted with but they are all interchangeable and none of them would affect the geometry
Shamelessly swiped from the DSC website, as I was looking rear shocks up recently myself:
skidlids said:
From what I recall the standard 600SS shock is about 330mm with the later SSie shocks being 335mm long, my Hagon shock is 7mm longer than my original 600SS shock
the Ohlins DU235 shock for the 900SS is 328mm +12mm, when fitted to a 900SSie its +5mm and -7mm as the standard injection shock is 335mm between mounting centres.
As I have just fitted a Ohlins to the 750SSie I will be able to try it at anything up to 340mm but so far have it set for 335mm while i try to sort the rest of the bike.
http://www.ducatisportingclub.com/showthread.php?t=35265
At the weekend I measured them more accurately and found the ie shock to be 7mm longer than the carb shock. Put it in and have since tried the bike without altering the forks. It does feel a tad quicker steering and it isn't wishful thinking. The bike also leans a bit more on the sidestand. Info I've picked up says the Carb shock should be 330mm from mounting bolt centres and the SSie should be 340mm.
The free length of the shock is (almost) irrelevant ... what matters is how long it is when loaded (fnarr!) ... depending on the spring and how much preload is dialled into the adjuster nuts will determine the actual ride height and thus the steering head angle when you are sitting on the thing. Either of those shocks could be adjusted to be steeper or shallower than stock just by adjusting the pre-load (and thus the ride height).
Free lenght is sorta relevant, but it does not necessarily determine the ride height when actually under load ... what you shodl have done is measured the actual ride height with you seated on the old shock, and then put the new shock in and measured the ride height again, that would have given you a definitive answer ... it could be the ie shock has been fitted with a softer spring, or had the pre-load wound down by the previous owner, and is actually running lower than your old shock ... or it may have more preload wound in and despite only being 7mm longer could be running 20mm more ride height and need tweaking down a little.
Ride height is all that counts in the end ...
The springs were identical in length, diameter and thickness. It was the damper body which was longer. Anybody know how much 900SSie forks protrude from the top yoke?
Information about the front end. The distance from the bottom of the bottom yoke to the top of the stanchions on the carbed SS is 268mm and on the SSie it is 296mm. The only problem is that I know the carbed bike has different forks from the injection bike. I need to find out if the lengths of the stanchions are the same length, then I can set the geometry on my bike up the same as the injection bike. If it's good enough for Ducati it's good enough for me. Anybody got any info.
