Tam
Right techeads.
The Haynes manual says the engines got to be removed and the cam belts to remove the vertical cylinder
Is it possible to do it in place so i can change the studs and ''o'' rings or am i fecked
Thought you'de have enough space if you remove the tank and the air box and the rear shock:dunno:
