900ss total electrical failure
johncool1979
hi my 900ss has no electrics at all when i turn the key on
i have checked all fuses and the battery it just wont turn the dash on!!!! any ideas
john
howdie, search for a thread in the last few days on multistrada electrics, Winston has a similar problem to you on his multi and Derek mentioned that it might be the main relay.
Hmm. Deadbikes seem to be catching.
What year is you bike John? The SS is something I do have wiring diagrams for and experience with.
If you have absolutely no power to anything I have sorted my Multistrada problem tonight and just posted the answer. Hope this helps. It was a bit painful and an iterative procedure testing power from connection to connection, I had no power anywhere and it turned out to be a corroded connection.
yea there seems to be a theme running here atm, could it be winter ?
prolly just co-incidence mind you.
/ian
John,
I hope you've now got the wiring diagram.
At the battery +ve you will see there are 2 red wires. One is the hefty one to the starter solenoid, ignore that one. The other lighter wire goes first to a multiconnector. That should be at the LH side of the fairing subframe. From the multiconnecter it then goes to Fuse 1 which is a 30A. This is the Main fuse and should be live at all times, ignition on or off.
From the fuse it goes to Pin 30 of the main relay. Pin 87 of the relay has a brown wire which returns to the fusebox and all the other fuses.
The output from the 30A fuse also splits off to the ignition switch pin 3. When the key is turned it connects to pin 6 . This then connects by a red/white wire to pin 85 of the relay, so that when the key is turned power is applied to the relay coil, which closes the relay points providing power to the fusebox.
Firstly check for 12V at Fuse 1, If nothing check the multiconnector for corrosion and that it is fully seated. Corrosion here is quite common.
If you have 12v at Fuse 1 then the odds are that the relay is faulty, that’s also quite common.
I hope that helps.
900ss sorted
hi
trhank you derek for all your help
i have fixed it it was the starter relay it was all dirty inside so i cleaned it out and it all powered up
many thanks for everyones advice
john
