I'm trying to find out some spec's for the bearings - I simply took my old ones to a bearing stockist and they replaced them with identical SKF taper rollers for £12 each!
Here are some good tips I've found:
"remove fairing, get the front end supported(I have an engine stand), remove guard, wheel, forks etc. Ashamed to say I used a mallet and substantial screwdriver to loosen C-ring but managed not to mark it. You might want to mark where your forks are in the yokes before dropping them out, and take a note of the order that locking nut, washers etc come out in.
Haynes is okay as a guide for this though from memory the pics aren't particularly instructive."
____________________________________________________________________________________________________
"Just removed the bearings off my T8 the bottom inner race I removed with a dremel with the little cutting disc attatchment cut through as far as possible without touching the yoke.
then with a small sharp chisel place in the groove and tap with one hard blow this splits the shell and it then pulls free.
make sure you have the yoke on flat but shock absorbing surface I used a bit of hardboard on the metal work bench.
hope this helps"
"Outers are obviously are the problem in the head stock.
Inners in the steering stem were the other one I remember! and the worst one for me - wish I'd of know about the Dremmel trick as I say a mate at work used an Oxy torch and burnt my lower one off - the heat was a bit drastic to say the least.
I simply used a long tube to remove the outers - not much of a lip to work with in the frame - I recall it took a long time being patient and working around the bearing evenly.
Assembly really was easy - outers in the freezer overnight and then hairdrier in the frame tube, no problem there.
Inner lower bearing needed a tube to press it right the way down the stem - all pretty straight forward really.
I would not bother trying to ABSOLUTELY seat them either as riding the bike and bedding the bearings in finally seemed to entail a few bearing adjustment sessions - but was fine in the end.
Be methodical - use a bearing specialist (not a bike retailer) and I'm sure you will be fine."
"The numbers are:
SKF:639174
SKF:639172
With thanks to user Jasper over at the DSC website; photo also
Cheers - Frank
NB - Cant confirm sizes but just seen a post stating 26 X 52 X 15
