900SS/SL Suspension
Pict
I realise that you are all off mashing midgies, but here goes. The SL had been lowered for the previous short owner so I need some info not in the manual
Rear shock;
  • What is a good 'base' setting for preload?
  • Factory setting for compression?
  • Factory setting for rebound?
Forks;
  • Are fork tops flush with top of top yolk?
  • Are clip-ons up against bottom of top yolk?
Cheers, that's good stuff, but could use some quick and dirty settings just to go round the block a few times. Will set it up properly in the winter along with all the other service jobs that need checking / doing. Thanks for the speedy response.
