900ss fuel pump wont prime
OK.. so my guess was, even though I don't what the reading means on the continuity test, I was getting a reading so it has continuity..
I decided to turn ignition and test volts at pump. At first, nothing then with a wiggle of the plug, the pump started up!
It appears to be the positive going into the plug that is dicky!!!
Look at this electronic guru go!!!
It's always the little things that kill dude, screw the spark plug into the HT lead tighter then maybe a result?
The plugf or the fuel pump I meant..
The plug ffs!!
So while I had the pump and filter out, I thought it made sense to replace the filter..
I called a bike shop in town that said they may have something that will fit.
Anyhu, the brake pads I got for the subaru were incorrect so I thought I'd swing by the bike shop while in town changing pads.
Armed with pics and measurements of pads I we t into the shop to change em, we identified the correct ones.
Out of stock..
The nice chap I was dealing with did a Google and found a shop round the corner that did have some so I got a refund and headed there...
Brake and transmission was the shop. Never been there before. Really good and cheaper than the other place.. while there I asked what else the stock. He said what you after?
Fuel filter for a 900ss.. maybe..
Got the filter outthe car and showed him. 5 mins later he had found one out the back.
12 kiwi dollars. Happy days! Do t know what the ducati shop would have wanted but probably 5 times that if it was a genuine part!
Just got to.put it back together now..
Soooooo.....
Got filter on and pump back in. Pump priming although I've not addressed the lose wire thing. Hit starter, nothing. Put meter in battery 12.4 volts. Hit starter, fuse blows..
Put that down to lose wire? Change fuse, turn on key pump primes, don't, does, don't, does .
Wiggle red wire in and it primes continuously..
Disconnect plug. Can't work out how to get terminal outta plastic plug. Tried pushing through with a tiny driver but no dice. Squeeze terminal a bit and reconnect plug. Primes continuously even when wriggling wire. Hit starter, nothing. Maybe battery too low? On charge now so will try later. Not holding out much hope though!!!
How do ya disassemble these plugs?
usually a special tool as it is 'clipped' inside, if it's in tight is should be fine - better doing a continuity test than messing with the connecter and maybe breaking it. Blowing a fuse would suggest more like a starter issue - how long since it last started?
Started a few months back. Then the pump stop priming. Now with bit of wiggling of the plug, the pump primes but it don't turn over and blows the 15 Amp fuse. Few days back it was turning over no problem at all
I haven't given this a lot of thought but what else is on that same 15A circuit?
My T9 died at Cadwell one time, I thought it was whenever the starter turned over, it would blow a fuse. The bike ran but if it stopped I had to replace the fuse to start the bike again.
The root cause was the front brake stop lamp microswitch. Whenever I applied the front brake, the fuse blew as the stop lamp is on the same circuit as the starter motor (plus another item, I forget which, maybe horn?).
So what else could be going wrong aside from the fuel pump?
Probably no help to you. Sorry.
As far as I'm aware, only the pump and starter are on that fuse...
So... its on the starter side I think as when I disconnect the fuel pump and hit the starter the 15 Amp fuse pops..
Weird as it was cranking over All good till I got the pump working..
Chiz, It's possible there is a short some where on the pump starter circuit, hence the pump connector problems.
Also just as an afterthought, is it possible the engine could have hydro locked with the bores full of fuel? Unlikely but!
Don't think it's on the pump side as I disconnect the pump and the fuse blows when I hit the start button..
