900SL/SS - Engine Removal.
Mr-Superlight
As I may have sourced an engine to use in my SL (bottom end issue) I am now looking to remove mine that is still in place in advance of the engine work/swap.
Is there anything I need to look out for or tips / special tools etc that the knowledgable people on here would care to pass on?
Cheers,
Andy
Cheers - that thread pointed to is pretty mighty ! End result looked good - maybe one day .....
I'm cracking on over the next few days, about 1/2 way there, so far no major issues, airbox, oil cooler off, exhausts and wiring prob the remaining major bits left to do.
Thanks again, No problems so far, taking pics as I go to hopefully reduce the number of nuts and bolts that I find sitting on the garage floor after it is all back together (fingers-crossed) and wires the have no corresponding plug to connect to !
Tank/airbox/coils/oil cooler off, think main bits are wiring (starter etc) and exhausts - I found all of the nuts on the header-engine all came loose more easily than I'd expected when I tried these yesterday.
With regards the replacement engine I'd swithered on using my heads (which I don't see as having any problems) or just replacing the head studs on the one I am getting and using that complete one but I believe this to be from a 2002 Monster = low-performance cams (as per 'bikeboy').
My own is a 1996 (within the period for the best heads) whilst post '96 Monster are poor. When I see the engine I can check the engine number but has what bikeboy says been found to ring true always ?
http://bikeboy.org/900equal.html
The post 97 monster 900 engines had smaller valves, as Derek says you want the V2 stamped heads, its visible on the side. The heads are restrictive enough on these engines without smaller valves and if you are planning any further mods itll justbe pointless. As regards the cams there are different ones but you can swap a lot of parts from one head to another. Pre 97 900 parts are the best though as they strangled the later ones cause of emissions.
The Monster engine I've got the chance of is actually a 1994 or 95 and has V2 stamped heads. Seems in decent nick - from a bike that had a front end crash with the frame damage resulting in w/o. Internally, to my untrained eyes, it seems pretty unworn, no wear marks on the bore etc, pretty clean oil dribbling out.
As an early engine it seems to have the problematic stainless studs - the seller has 4 replacement studs and it seems sensible to do all 8.
Other than base gaskets I think that's the basics covered - if I go down that route ?.
Andy,
A lot of the earlier engines had their studs done over the years. The newer ones have an 'O' stamped on the end and are dark in colour. Be warned they can be a pig to remove and easily snap, which means a lot of hassle to rectify. Use heat if you can and two nuts on the end locked against each other. When I did mine I left two of the old non stainless ones in, simply cause I broke at least 3 and didnt want any more grief. They looked good too so I only replaced 6.
Just take it slow.
Ian
Ian, The seller had 4 replacement studs (to do the 1 head that had a broken stud in I'd assume) and these new ones were dark and magnetic as opposed to the ones in place which were definitely very shiny stainless/non-magnetic. Stainless ones are the ones that give issues - Yes ?
If the heads are coming off anyway then it is worth sorting all the studs despite the potential issues that can arise during removal ?
Andy
Andy, absolutely, its just it can be a bit tricky thats all. You are correct, those are the studs that give issues. If the heads are coming off, then are you putting in high comps? :D
Thanks for the hints and tips - this Monster engine would go in as untouched as is sensible. A secondary plan I've considered is to hold on to my original engine and in a couple of years have that rebuilt to a higher-spec when I have more time to sort that out. Might seem strange to kinda do the job twice but for the next 18-24 months I pretty much know that I won't have the time or money to get that sort of job done.
Will be looking at the build-up of the replacement engine that I've now got sitting in my garage.
I know that the list of parts I'll need at the moment uncertain but wonder on a couple if items :
Belts : Not sufficiently picky to demand Ducati ones - where is the best source for the acceptable alternatives such as Exactfit ?
Gaskets etc
I'll need 2 x base gaskets for sure, no head gasket ? Can't recall without the engine in front of me whether there is an 'o' ring ?
I think there is a top-end kit but as I am trying to do only what is required then that might contain more than I need ?
There is an o-ring at the base of the vertical cylinder which is very prone to leaking. Other than that there are only the cylinder base gaskets at the bottom, which are made from aluminium. I might have a couple lying around.
At the head joints there are two 0-rings on the horizontal cylinder and three on the vertical. They are all easily sourced from a bearing stockist just make sure they are made from Viton. There is also an o-ring behind each of the covers on the barrel where the oil return take-offs attach.
The only gaskets are for the valve covers and the bearing support cap. If the gaskets are the plastic coated metal ones you will probably be able to re-use them although it's best to fit a new one on the vert exh cover as it sits full of oil.
ExactFit belts are imported by a guy calling himself Exige on the Ducati.co.uk forum.
If you subscribe to the forum, you get a discount that exceeds the cost.
Getting the belts from him is way cheaper than importing them yourself.
Alternatively, you can find him on his ExactStart website or on ebay.
He calls his site ExactStart because he also supplies starting circuit kits for Ducatis.
The oem starting circuit cables are marginal at best when new and only get worse with age.
I have a cable kit on my 999 and it's the best money I've spent on it, I only wish they'd been available when I had an SS because starting that was always a fingers crossed affair and I always worried that I would get stranded one day. Even with a new battery it always struggled to crank and would often catch only when I took my thumb off the starter, as though the current the starter was taking was leaving insufficient for ignition.
I hoped the 999 would be different but it wasn't :(
It was with a cable-kit though - no more worries, it just cranks and starts. Result :)
I am now about ready to get the engine out of the frame ( I move slowly - holidays etc blocked quicker progress).
I think it standard procedure to have the bike raised so that a trolley jack (plus blocks of wood) are positioned below.
The engine sits so low to the ground and I don't have a hoist to easily position the back-end up and down so I wonder if the opposite route could be used, ie setup blocks of wood to sit supporting the engine and then, once unbolted, the bike sans engine are lifted away ?
I've the swingarm off and the rear now held using straps attached to garage roof beams. Only alternative I can think of is to raise the front wheel sufficiently so that trolley jack+wood can get sufficient clearance.
That's how I did it when I replaced my frame, except that I left the swing arm and rear wheel in place. Took the forks and front wheel off though.
Cheers - swingarm and rear wheel are off mine so I should be able, once the frame is free, to roll the frame forwards.
Think pretty much every cable and bolt are now detached to allow this to be done asap.
1 thing I found was the bolt holding the 2 sections of the collector / exhaust just below the gearbox is well seized, managed to get this out in 1 piece but was a hassle and want to separate these - thing some application of heat is the next action for that as the bolt feels like it will shear - I can see the rust , soaking in GT85 hasn't helped.
When you took off the swing-arm did you note the swingarm to engine shims?
Given you are changing the motor you might need to think about which widths to use when you rebuild.
I did - they are placed on the bolt, as I recall there were 2 x thicker ones on one side and 2 x thinner on the other but thanks for the reminder : I will measure up the 2 sets of cases.
Mr Superlight, your method of removal is sound. Get the engine on something stable and remove bolts wheeling the front away, its quite light once everything is off. I made up a small table/box structure out of wood so that once the engine is on it its the right height to remove all the parts or reassemble with the same height as the bike sits with both wheels in, so that its easy to slide under and dismantle the bike...if that makes sense
Y, that's what I'm planning to do - either one/2 workbenches using some sort of stands or I've some bits of wood from a TV unit no longer needed that I will make into a suitable stand.
