900 ss rear head removal
Davie
just got the thing ready for its mot on monday and its broken a rear cylinder stud :banghead: is it possible to remove the rear head and cylinder with the motor still in the frame
:eek: Sorry don't think so.
Here's a stripped down look at what your up against.
Studs..
Yes it is! I replaced all 4 studs from the vertical cylinder on my 900ss last year with the engine in situ. Just loosened everything - the motor canted forward sufficiently far enough to remove/replace the studs;)
The new studs are supposed to be stronger.
You can tilt the engine forward by removing the front engine mounting bolt, just make sure you loosen any wiring and have a jack at the front so you can lower it gently.
