as ducati are no longer makeing them i need an alternative fitting to screw on the bottom of the tank is there any other models with a fitting that would fit or anybody know what thread they use ?
if youve got the original it is worth trying gordon at eclipse motorcycles in tranent as he used to be able to get things like that for old british and japanes bikes 01875 611400
If you have a look over on DSC I know it had been discussed amongst the dd racers. Many had fitted early tanks to later bikes etc and I know someone came up with an alternative to the original part....much cheaper too.
How about using a fitting on the tank with a straight line pipe connection and the splitting the carb feed hose with a QD connector that would shut off the flow when separated???
