900 ss carb change and problems...
jota996
HI all
new to this site but not new to the perils of Ducatidom.....
I have a 1990 900ss, the one with the Weber, I gave up with the Weber and changed it to a pair of Mikunis from a 900 Monster...
The bike will start now and run up but Im getting a backfire through one carb.... occaisionally at lower rpm... if i look down the throat of the carb I can see that one of the slides doesnt return as quickly as the the other....
Also ive been advised that the carbs have Dyna jet needles in them....???... they were badly gummed up as the carbs ahd sat for a while before I fitted them, anyone know where you can get just the needles?.....
Cheers all....
Stu
Welcome to Dun!
Sounds like one of the idle jets is blocked. Had the same thing on mine just a few weeks ago as the carb had been sitting for a long time.
If it runs better with a bit of choke almost certainly that is your problem. You could be drawing air in as well but more likely blocked jet(s).
Pull the bowls off and take the jet out and see if it is clear and either clear it or replace them.
http://www.allensperformance.co.uk/ and a couple other place will have the bits.
The Dyna jets are probably just on the main and they are unlikely to be the issue.
If the slides are not returning at the same time they need adjusted but your idle jets are your first port of call.
PS When you have the bowls off see what size of mains are fitted. Could be it was set up for a K&N filter and open pipes which may mean they are too big for you if you are running a standard set up.
thanks for the reply...
might be a daft question but which ones are the idle jets ?...
the bike has standard silencefrs on it , but as you cant get a real airbox on it with e battery tray being in the way Ive fitted a pair of ram air sock filters.....
Sorry my IT skills not great but this may help.
Shown as "pilot" jet.
Usual trick with the airbox is to cut the lid to let more air in and fit a K&N style filter. I got a similar from Wemoto at a fraction of the price on Ebay. They seem to sell the odd bit on there way cheaper than from their shop.
However you have to be careful cutting the airbox as you can end up with water running down off the tank straight into the filter if you cut it in the wrong place.
Carbs ideally should be sitting in still air so not sure how your sock filters are set up.
I couldn't be bothered with guesswork on my setup which had K&N style with a one off exhaust and stuck it on a Dyno.
Turned out the correct main jet should have been about 50% bigger than standard size.
The bike did run before but until I saw just how lean it was running on the graph I would never have believed it was that far adrift.
Others that know what they are talking about may be along to tell you differently of course. :)
Check the diaphragms are not damaged, one of mine was nicked at the edge and I had to do a temporary repair with a bit of o-ring. Also, the Dynojet kit has different throttle slide springs. Maybe you should check that both springs are the same and haven't been mixed up.
thanks desmo, that link goes to google....lol
Ill investigate the springs as well.....
what sthe standard setting ffro the mixture screw... how many turns out?.....
239desmo's link should show you this:
Idle jet is number 11
Good luck.
Yes full turns, both cylinders the same. Start off at 3.5 turns then once the bike gets warmed up close them 1/2 turn at a time and note whether the revs rise or fall. If the revs rise keep closing the 1/4 turn at a time until they start to drop, or if the revs drop open them up again. The aim is to find the idle screw setting that gives the highest revs then open them a further 1/4 turn and that should do it. Finally re-adjust the idle speed for 1100-1200 rpm.
You should also check that the butterflies are balanced.
