900 ss & 916 front wheels
Davie
are the wheels interchangeable the disc & hub width is the same are they a straight swap or are the bearings different
its only for a mot
Only if its an inj. SS wheel with the hollow axle, Davie. Your Superlight will have the solid front axle I think. Frustratingly everything else is identical.
So much for that plan think i will purchase an impact driver and see if that will slacken the bolts on the disks
you got your bike on the road yet ?
Sent my heads away to CJS engineering to get gas flowed and ported. No doubt I'll find something else to avoid riding the thing after that!
is there much to be gained ? i thought the long intake manifolds were the problem on ss engines
Well, Chris at CJS said I'm probably looking at around 90bhp with the present set-up; split FCRs with short manifolds could push it to 95+. Kaemna in Germany do a conversion to split duals for around £350 and a new set of split FCRs is £840, so won't be happening for a while.
Would be simpler and cheaper to buy a 1000ss but where's the fun/grief in that?
