900 sl oil temp
Davie
Had the bike out for a run today the oil temp seems to sit around the 90 to 100 on the motorway pottering along at about 80 to 90 (private motorway)
is this about what to expect or a little high in stop start traffic it heats up a little more to about 110-120
yep pretty normal,thats what my bike gets up to, (depending on the weather,80/90, when is around or below 4 degrees something like that) if not 100 to 120
...try running the thing at sustained High rpm for two hours (at Knockhill maybe!) and see what it does then... :eek: big oil cooler city!!!! ;) :)
So what is the sorta temp to expect at this time of year ?
I don't run a temperature gauge on the Imola. I run the thing up carefullly (not exceeding 4000rpm) for the first 10 miles until I'm happy that every component inside the engine has reached running temp, thereafter, take it right to the top!!! It has quite a range so at this time of year expect to see it going from cold to very hot. It's an old air/oil cooled motor which compared to modern engines isn't the most efficient cooling device. Lets face it, it only has a small oil jacket surrounding the cylinders, the heads are air-cooled.
If you can keep the temp below 100 then you'll be doing fine, larger oil coolers help with this!
Fact of the matter is, don't worry about it too much. :)
