851 Reg/Rec
David
I've just been sent (and now fitted) a Tour Max reg/rec for my 851 (I'd ordered Shindengen, but this is what arrived!). It's a 3-wire (ie 2 phase) type, and of course the alternator is 2-wire. The dealer supplied it with two of the yellows connected together because "that's what his supplier had told him to do". But I've seen other contributors in the Forum stating that you should leave one yellow disconnected. Had a couple of rides without any issues (yet), tho' voltage across the battery is only 13.4 at 3-4000rpm (thought it may be a bit higher...). Any views??
I'm not familiar with Tourmax regulators but you should have been sent a single-phase regulator with just 2 wires to the alternator (incidentally the 3-wire is a 3-phase alternator, there is no 2-phase). Connecting 2 yellow wires together won't do any harm but your output of 13.4V is a bit low. You really should see more like 13.8V - 14.00V.
Does the regulator have a brown wire? If so it is a voltage sense wire and should be connected to an ignition switched 12V supply. You would have been better with the Shindengen FH012. It's also a 3-phase regulator but you leave the spare one unconnected.
