848 Hel front brake lines ?
Garcher
Hi lads
Today I decided to change my front brake lines from the single one down to the right caliper, then over the mud guard to the left caliper. I changed them for the full race setup offered by Hel, which is the two lines coming right off the master cylinder one left, one right.
The issue I came across doing this are Hel do not mark up the hoses telling you what end goes to what location. Not a big deal I thought as obviously the longest one goes to the left and shortest to the right.
I noticed that the standard lines come off the caliper and towards the radiator but the new Hel lines are not long enough to do this and on full lock the hose is under a bit to much tension which is not be a good idea. The only way I could get them on and not be to tight is to come off the caliper and point towards the forks instead, is this correct ?
Would be good if Hel gave you fitting instructions for each setup other than just how to bleed the brakes but they don't.
Just wondering if anyone has come across the same before or am I being a mong and fitting them wrong ?
